Testting's avatar
Testting
Follower
Jun 06, 2021
AC1200 WiFi Cable Modem Router not accepting default password after factory reset
Hello,   I'm trying to login and change the name and password on the wifi connection. I bought a AC1200 WiFi Cable Modem Router back in 2018 and kept the default network key until now.   First, I...
  • antinode's avatar
    Jun 06, 2021
    > First, I created a Netgear account and I went to routerlogin.net [...]
       Why?  An account at netgear.com is unrelated to the "admin" account
    on your router's management web site (routerlogin.net).  And neither is
    related to any wireless "network key".
    > [...] I downloaded the Nighthawk app [...]
       Not necessary.  Does it support your modem+router model?
    > Any help would be greatly appreciated!
       You might try this radical concept which works for some people:
          https://en.wikipedia.org/wiki/RTFM
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for
    "Types of Logins" and "Specify Basic WiFi Settings".  Further reading
    might not hurt, either.
