Muni
Dec 05, 2022Follower
AC1200 WIFI Model R6120 Power button light continue blinking
michaelkenward
Dec 05, 2022Guru - Experienced User
Before you put too much effort into fixing this router, how fast is your Internet service?
If it is anything near 100 Mbps, this router could be slowing down your traffic.
According to Netgear's manual for the R6120, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. (Actiallt, the manual sats 10BASE-T biut I donpt bvelieve ythat,) That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet, anything faster than 100 Mbps is a waste of your money.
It also slows down whatever is going on in your local network. Newer devices support at least 1000BASE-TX.
The Wi-Fi may also not be up to much. It might not even support 5 GHz wifi.
Nothing wrong with it being old, just don't expect too much.
If you have a service that is faster than 100 Mbps, take this as an opportunity to get something that can handle 1000 Mbps, which is just about every other router you can buy.
