netdobbz62
Dec 11, 2020Follower
AC1200 wifi range extender model 6110,is this model obsolete? I use win7 in 2019 when I got it
having a bad time trying to make it work,was it too a 2G device that no longer works? range extender 6110 , I sure tire of having to buy stuff all the time. TL
Dec 11, 2020Guru - Experienced User
What router do you have it connected to?
What firmware is on it?
Did you set it up using wps or the installation assistant?
