Luz05
Apr 28, 2022Aspirant
AC1200 wifi router R6120 problemas de conexion wifi
Apr 29, 2022Guru - Experienced User
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Luz05
- plemansApr 28, 2022Guru - Experienced User
not much to go on. Just a router model.
Its a great resource to start with.To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days. - michaelkenwardMay 01, 2022Guru - Experienced User
One of Netgear's slowest routers. Not much use if your Internet speed is faster than 100 Mbps.
