Juary
Jan 01, 2023Follower
AC1200 Wifi Router
Router light keeps turning red 3rd light. Continues To ask me to agree to policy and then to sign in I've changed my password twice should I not be trying to do this on a mobile device?
michaelkenward
Jan 02, 2023Guru - Experienced User
What Netgear device are we talking about?
AC12000 is not a model number. It isn't even a WiFi standard.
If you mean AC1200, that is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
