BKKbob's avatar
BKKbob
AC1450 power light flashing after firmware update
I tried updating firmware and I think the update failed and now the power light is flashing continuously.  Cannot access via lan cable and wireless signal is not functioning.
  • ElaineM's avatar
    ElaineM
    Feb 23, 2016
    BKKbob Those steps should help you. Did you still proceed with the rest of the step even you didn't get a blinking green power LED?
    If that step didn't help, see this other link for a different TFTP step.
