bobbyclarke
Aug 31, 2022Aspirant
AC1570 Attached Devices
When I view the Attached Devices on my AC1750 why do I see wired devices? I have a Netgate pfSense firewall with a WAN connection to the ISP, a LAN connection to the unmanaged Netgear switch which is...
michaelkenward
Sep 01, 2022Guru - Experienced User
Which router is this?
AC1750 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
- bobbyclarkeSep 02, 2022Aspirant
Model R6400v2
- michaelkenwardSep 02, 2022Guru - Experienced User
bobbyclarke wrote:
Model R6400v2
If this is in AP mode, you hit this:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Maybe that affects what shows in attached devices.
I prefer the map in the desktop genie.
- bobbyclarkeSep 07, 2022Aspirant
How does this answer my original question?
