horserider
Nov 09, 2020Aspirant
AC1600 Amber light on internet out (3rd light from left) Slow
Slow download speeds of 30 mbps Xfinity confirmed minimum 200mbps coming into modem/router. My service is rated at 200 to 300 mbps. The 3rd signal from the left is solid amber color - internet out or download. I do not know how to correct this issue. I have never updated with any firmware. Purchased unit in September of 2018.
do you have a screen snip of your cable connections page and your logs? that helps us check your line.
The 3rd light from the left is upstream and it usually means only 1 channel is locked on the modem. Usually indicates line issues.
How did xfinity "confirm" a minimum of 200mbps to it? did they come out and connect to the modem or just say it over the phone?
What speeds do you get hardwired into the modem?
If you have any splitters, amplifiers, or signal attenuators in the coax line, remove them. Check your coax for kinks, damage, poor/cheap connectors, loose connectors.
- horseriderAspirant
Xfinity rep on the phone advised 200 mbps coming into modem, 300 mbps on our contract. They Xfinity tech rep rebooted the system/modem but that did not help. I also unplugged it, waited 5 minutes to power up but still same issue.
I have to purchase another ethernet cable to try a speed test hard wired which I will do tomorrow. I used the ethernet cables supplied with the Netgear modem.
There is a splinter that I attached a pic of. It has the Xfinity cable from the wall connected, then the line to the cable box and a line to the modem. Not sure how to otherwise hook up properly. to cable line and cable box.
No kinks in cables/lines, they are all securely fastened. Is the screen shot you need under the NETGEAR properties on my wifi settings?
