MaryT54
Jul 31, 2020Aspirant
AC1600 R6260 installation problem
Hi - I just purchased the AC1600 R6260 wireless router and I cannot get it to connect to our internet when following the install instructions. The old router was working, so I know that the modem and...
- Aug 02, 2020
You can get to the admin console with all the router settings by plugging a computer into the router with an ethernet cable. Open a web browser and type in 192.168.1.1 and you will be prompted for a password and it will lead you through the setup. Default is user: admin password: password . If it doesn't recognize the internet after it leads you through the setup then try messing with the Internet IP settings I mentioned in the previous post.
I know the struggle lol just dont give up! Once I got it working it actually increased my network speed by 3x.
MaryT54
Aug 01, 2020Aspirant
Your last paragraph would have been a sufficient reply.
antinode
Aug 01, 2020Guru
I had no way of knowing that, either. The preface was your own
personally customized guide to asking a technical question, in case the
product documentation was not enough on its own. You can keep it for
future reference. You're welcome.
Does that mean that you found a solution to the problem (whatever it
was)? (Care to share?)
- jccourtnAug 02, 2020Tutor
I had this same problem yesterday setting up a R6260 AC1600 wireless router. My solution was to set up the configurations manually in the Internet Setup tab. For some reason the router was defaulting to a static IP address. When I changed the "Internet IP Address" section to Get Dynamically from ISP it was finally able to recognize the connection. I also changed the "
Domain Name Server (DNS) Address" section to 1.1.1.1 and 1.0.0.1 for Cloudflare DNS but I don't think that is what ultimately fixed the problem.Also Netgear, the password that was provided on the routers sticker was not correct. If I wasn't an IT professional that would have caused a huge headache. Otherwise, it works great once configured properly.
- MaryT54Aug 02, 2020AspirantWow - can we hire you to help us?😆
We don’t have the technical know-how to handle this installation I’m afraid! It is more complicated than the first one we got many years ago. Anyway, thanks for the reply! We will keep trying.- jccourtnAug 02, 2020Tutor
