MaryT54
Jul 31, 2020Aspirant
AC1600 R6260 installation problem
Hi - I just purchased the AC1600 R6260 wireless router and I cannot get it to connect to our internet when following the install instructions. The old router was working, so I know that the modem and...
- Aug 02, 2020
You can get to the admin console with all the router settings by plugging a computer into the router with an ethernet cable. Open a web browser and type in 192.168.1.1 and you will be prompted for a password and it will lead you through the setup. Default is user: admin password: password . If it doesn't recognize the internet after it leads you through the setup then try messing with the Internet IP settings I mentioned in the previous post.
I know the struggle lol just dont give up! Once I got it working it actually increased my network speed by 3x.
jccourtn
Aug 02, 2020Tutor
I had this same problem yesterday setting up a R6260 AC1600 wireless router. My solution was to set up the configurations manually in the Internet Setup tab. For some reason the router was defaulting to a static IP address. When I changed the "Internet IP Address" section to Get Dynamically from ISP it was finally able to recognize the connection. I also changed the "
Domain Name Server (DNS) Address" section to 1.1.1.1 and 1.0.0.1 for Cloudflare DNS but I don't think that is what ultimately fixed the problem.
Also Netgear, the password that was provided on the routers sticker was not correct. If I wasn't an IT professional that would have caused a huge headache. Otherwise, it works great once configured properly.
MaryT54
Aug 02, 2020Aspirant
Wow - can we hire you to help us?đ
We donât have the technical know-how to handle this installation Iâm afraid! It is more complicated than the first one we got many years ago. Anyway, thanks for the reply! We will keep trying.
- jccourtnAug 02, 2020Tutor
- GaryGottAug 10, 2020AspirantIâm next to a condominium Bldg and I believe there is another âNetGear05â logon nearby, so my laptop wonât connect because of the âother network with the same name â
How do I change the name?- antinodeAug 10, 2020Guru
> I'm next to a condominium Bldg [...]
Instead of creating your own, new thread for your own, different
problem, you joined this old thread, and then, apparently, paid no
attention to the advice in it. Why?> [...] Here's a radical concept:
> https://en.wikipedia.org/wiki/RTFM
> Visit http://netgear.com/support , put in your model number, and look
> for Documentation. Get the User Manual (at least). Read. Beyond the
> basic set-up instructions, look for the LED descriptions and
> "Troubleshoot".Look, too, for "Manage the Basic WiFi Settings and WiFi Security of
the Main Network". Further reading might not hurt, either.
