Mason01
May 09, 2022Aspirant
AC1600 won’t connect to internet
I have a net gear AC1600 and it has worked awesome for the 10 months I have had it. A few days ago it stopped connecting to the internet (device says WiFi has no internet connection).    It works for ...
Mason01
It is a combo device. C6250-100NAS Is what the box says.
How do I access those logs? It won’t even let me access the net gear nighthawk app currently.
May 09, 2022Guru - Experienced User
log in through the browser. go to 192.168.100.1 on your pc/laptop
what are the led's on it doing? (all of them, color, blinking, etc)
- Mason01May 11, 2022AspirantPower light is solids green. Download light will flicker on and off until it connects and then it’s solid, the upload light will flicker and then after about 15 minutes it restarts the process. All are green. 5GHZ and 2.4 GHZ are solid green entire time.
- Mason01May 11, 2022AspirantFollow up post for logs photo- plemansMay 11, 2022Guru - Experienced UserYou've only got 1 channel locked. You should have a lot more. Start with removing any amplifiers, signal attenuators, or splitters from the coax.
 From there check the line for kinks, damage, moisture in the line.
 Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
 If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.If this doesn't help, then the isp needs to check the line.
