CapeLady
Oct 27, 2025Follower
AC1740 Model R6350 & Xfinity Modem
I have a Xfinity WiFI Gateway and router connected to AC1750 SmartWiFiRouter MOdel R 6350. My internet speed is max 1000mbps but the laptop and desktop attached to the AC1750 (ethernet) will only r...
Oct 28, 2025Guru - Experienced User
You have a router at the ISP modem level already. The 6350 series is years old and of older generation WiFi that doesn't have the capabilities to support wifi speeds much past 300Mpbs. So if you want to see anything past 300Mpbs, you'll need to replace the R series router with something newer generation:
https://www.netgear.com/home/wifi/routers
Also, if your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communities
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
Good Luck
- StephenBOct 28, 2025Guru - Experienced User
CapeLady: You have a gateway (modem+router combined). Likely it outperforms the 6350, so one option is to stop using that, and just use the Xfinity.
You should be able to change the wifi network name and password yourself. Can you give us the specific model information?
If the gateway wifi isn't good enough, then you could get a newer Netgear router or access point, and connect that to the Infinity gateway.
