RocketmanSFCA
Feb 01, 2024Aspirant
AC1750 6400v2 Dual Band WiFi Router - unreliable 2.4Ghz connection
I've been using the Netgear AC1750 6400v2 dual band wifi router at home for about a year without issue. But recently, I cannot access the internet over the 2.4Ghz band. I have no issues connecting to...
Feb 02, 2024Guru - Experienced User
You can try changing the channel the 2.4ghz is on. 2.4ghz is more sensitive to interference than 5ghz which can cause issues. Channel changes might help and is worth
