Sboden
Oct 25, 2017Initiate
AC1750 access control greyed out
My R6400 wireless router has many features greyed out now. The big one for me is Access Control as I use this feature and can no longer turn it off and on nor add devices. It worked fine prior to a...
- Oct 25, 2017
Found the answer. I had to take the router out of AP mode which I didn't need to do prior to the firmware update.....
Sboden
michaelkenward
Oct 26, 2017Guru - Experienced User
Well done.
This explains what you lose when in AP mode:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
