pilot51's avatar
pilot51
Guide
Nov 12, 2021
AC1750 Access Point Stopped Connecting to Internet
My Netgear R6400 AC1750 router that was configured as an Access Point in my bedroom stopped working.  How I noticed it is when my Firestick could not connect to it. Then I checked my Iphone 8 and my ...
  • pilot51's avatar
    Nov 13, 2021
    Hello,
    I found the solution to my problem.
    I noticed that the middle light of the TP Link Powerline adapter in the room where the router is was off. I then brought the TP Link Powerline adapter from the bedroom, paired them, plugged the one back in the bedroom, and everything worked.
    Thank you for your concern.
