honey5050
Nov 27, 2020Follower
AC1750 C6300 Parental conrols how to
How to control children devices using netgear. Feature to enable or disble device usage
michaelkenward
Nov 28, 2020Guru - Experienced User
You own a C6300?
Visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.
See the section Set Up Parental Controls.
You may have done this already, but I can't tell from your message.
Your device is too old to support the newer Circle service.
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
