Dennis_
Sep 12, 2019Aspirant
AC1750, Internet suddenly not working
I've had this router for about 2 years without any problems at all, but suddenly (when i just built my pc, no idea if this is related to the problem) the internet stopped working (internet light on t...
- Jan 17, 2020
Sorry for replying to this post months later, but I'd like to let you know that I finally fixed the problem by using an ethernet cable tool to fix the end of the cable. I didn't try this before because the cable worked as normal directly in my pc and on a networking switch i used since the router stopped working. I guess I was too rough getting it out one time
Dennis_
Sep 13, 2019Aspirant
Thanks for your reply,
Modem: zxhn h369a.
Firmware version: V1.0.4.82_10.0.57
The ethernet cable is definitely correctly connected to both the router and modem as the problem can be fixed sometimes for small time by just taking out the cables and restarting the modem and router.
michaelkenward
Sep 13, 2019Guru - Experienced User
Modem: zxhn h369a.
And the make is?
Google suggests that this may be a modem/router.
Does it have more than one LAN port? Does it also do wifi?
- Dennis_Sep 13, 2019Aspirant
https://nl.hardware.info/product/418384/zte-tele2-zxhn-h369a
Not sure if that site is available in english but I hope you can understand what it says. It does have wifi
- michaelkenwardSep 13, 2019Guru - Experienced User
That is a modem/router.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. But some Internet service providers, such as BT in the UK, supply modem/routers that won't work in bridge mode. There may be ways to get the modem/router to cooperate, but sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR SupportThe fact that the thing worked for two years may mean that it wsas in AP mode eartlier and that the reset put it back into router mode.
The fact that it works for a time and then "hangs up" may be because it suddenly spots the conflict.
Thanks a lot!
That also explains why the problems became worse after the reset. Hope that will fix the problems
