Phil7701
May 29, 2023Tutor
AC1750 lost 2.4
Had to shut down a breaker at the panel, when turned back on I no longer broadcasting on 2.4. My 5 is ok. most of my home devices will only work with the 2.4. have powered off and unplugged a variety...
Kitsap
May 29, 2023Master
Phil7701 wrote:Had to shut down a breaker at the panel, when turned back on I no longer broadcasting on 2.4. My 5 is ok. most of my home devices will only work with the 2.4. have powered off and unplugged a variety of times, no luck. Did the breaker power up burn out the 2.4?
There are a lot of AC1750 class hardware devices.
Need to know the full model number of your router. Look on the nameplate on the back. Most likely starts with an R.
Phil7701
May 29, 2023Tutor
model C6300v2
