Phil7701
May 29, 2023Tutor
AC1750 lost 2.4
Had to shut down a breaker at the panel, when turned back on I no longer broadcasting on 2.4. My 5 is ok. most of my home devices will only work with the 2.4. have powered off and unplugged a variety...
Phil7701
May 29, 2023Tutor
model C6300v2
Kitsap
May 29, 2023Master
Phil7701 wrote:model C6300v2
The manual Wi-Fi on/off button is the second one down from the top. It controls both the 2.4 and 5 GHz radios. Toggle the on and off a couple of times to see if the 2.4 GHz radio comes back on. See attached screen snip.
Check both ends of your power adapter, the cord, and the receptacle it plugs in to. Maybe try a different receptacle.
- Phil7701May 30, 2023TutorYa, that did not work, looks like its toast, will have to replace, thanks for your help.
