MALCOLM1265
Jan 08, 2022Guide
AC1750, Model R6400v2
AC1750, Model R6400v2 I just recently updated to the recent firmware and now the nighthawk app cannot find my router nor the IP address work to login. Please help. Thanks
MALCOLM1265
Jan 08, 2022Guide
My modem is through cable provider Spectrum Model EN2251 is on the modem. The latest firmware 1.0.4.122 we did it yesterday. The internet is working I just cannot login to the IP address 192.168.1.1 as an admin to monitor my devices. The nighthawk app states it cannot find my router. So I reboot, reset everything and nothing is working. I just wish I never updated that darn firmware.
Jan 08, 2022Guru - Experienced User
Have you checked to see if its at that gateway address?
Pull up a command prompt in windows and type ipconfig
That'll tell you what the gateway address is.
- MALCOLM1265Jan 08, 2022GuideIt says it’s the default gateway..
- plemansJan 08, 2022Guru - Experienced User
so you're caught in a catch-22.
The next thing I'd recommend would be a factory reset and reinstall. But if it does the same behavior, you wouldn't be able to access it to reinstall it. You'd have to try to recover it using the tftp method of forcing firmware to it.
- MALCOLM1265Jan 08, 2022GuideFactory set the router..correct
