MALCOLM1265
Jan 08, 2022Guide
AC1750, Model R6400v2
AC1750, Model R6400v2 I just recently updated to the recent firmware and now the nighthawk app cannot find my router nor the IP address work to login. Please help. Thanks
Jan 08, 2022Guru - Experienced User
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
MALCOLM1265
Jan 08, 2022Guide
Yes windows 10..I will do the factory reset and keep you posted..
