GaACETech
Oct 18, 2016Guide
AC1750 Primary with 2nd AC1750 as AP
I purchased a AC1750 as a primary router with main SSID and Guest enabled. Both have a password. This works fine. I purchased a second AC1750 to be used as an Access Point (AP) for a side bui...
- Oct 18, 2016
Always read the documentation (actually sent to me by DaneA earlier). A main router ethernet port must be used to plug into the 2nd router used as an AP Internet port. I just plugged the 2nd router into a free port on the switch. Funny how the main SSID for the AP worked but not the Guest SSID.
I'll mark this as an answer unless otherwise corrected.
Darryl
GaACETech
Oct 18, 2016Guide
Darryl
