C-Hop
Oct 06, 2017Follower
AC1750 R6400-100NAS - instanllation deleted wifi from laptop
I just installed a new AC1750 (R6400) Netgear router. It appears that the installation genie has somehow deleted (it no longer even shows up as an option under Network & Internet settings) the WiFi ad...
- Oct 11, 2017
Hi C-Hop,
1. Are you referring to the NETGEAR Genie program? If yes, you can always have it re-installed by downloading it from the link below.
http://netgear.com/home/discover/apps/genie.aspx
2. The NETGEAR Genie is not required for you to have the router operational.
Dexter
Community Team
DexterJB
Oct 11, 2017NETGEAR Moderator
Hi C-Hop,
Dexter
Community Team
