Tankguitar's avatar
Tankguitar
Follower
Sep 04, 2017
AC1750 R6400 Nighthawk router
hello, been having issues since i got it, for whatever reason the router is capping my upload speed on LAN to a max of .6mbps.
currently subscribed to 5m upload, but when i hookup wireless with my phone, my phone is able to get a 6.2m upload.....what is making my wired connection so slow, i am having webpages drop before i can load them
ALSO, WHY WILL NETGEAR NOT LET ME INPUT AS AN R6400....
  • Hi Tankguitar,
    1. What is the firmware version of the router?
    2. Have you tried resetting the router?
    3. Does the issue persist on your other wired device/s?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Tankguitar,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Tankguitar,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
