gcgraham1701
Jun 23, 2017Aspirant
AC1750 R6400 port forward stopped working
I installed the R6400 three months ago and the port forwarding worked flawlessly until two nights ago when my two cameras stopped working across the WAN. Here is what I've done so far to fix it. Up...
- Jun 30, 2017
Figured it out. My ISP modem got scrambled and started handing out a private IP address to the Netgear Router although it was in bridge mode. Replaced it and all is back up and running just fine.
Jun 23, 2017Guru - Experienced User
uPnP disabled on the router?
- gcgraham1701Jun 23, 2017Aspirant
It's enabled.
- FURRYe38Jun 23, 2017Guru - Experienced User
When using any PF rules, uPnP should be disabled.
Thanks, FURRYe38. I'll give it a try!
