gcgraham1701
Jun 23, 2017Aspirant
AC1750 R6400 port forward stopped working
I installed the R6400 three months ago and the port forwarding worked flawlessly until two nights ago when my two cameras stopped working across the WAN. Here is what I've done so far to fix it. Up...
- Jun 30, 2017
Figured it out. My ISP modem got scrambled and started handing out a private IP address to the Netgear Router although it was in bridge mode. Replaced it and all is back up and running just fine.
gcgraham1701
Jun 29, 2017Aspirant
Just returned to the house to work on it again, sorry for the delay.
- Disabled UPnP and tested,did not make a difference.
- Backed up, reset router to factory defaults, and setup router from scratch with PF, to no avail.
The frustrating thing is that it was working for months. I even re-installed my original netgear router that also worked, and even the old router doesn't work.
Something has to be going on with my ISP. I'll try there again, unless you have any other ideas.
gcgraham1701
Jun 30, 2017Aspirant
- FURRYe38Jul 01, 2017Guru - Experienced User
Glad you got it working. Cheers. :smileywink:
- gyang1086Jul 16, 2017Aspirant
Hi, so did you call and get a brand new modem from your ISP? Is there not a way to reset the modem you have to fix the port forwarding issue? My PF was working great for around 3 months and this morning failed to connect anymore.
- gcgraham1701Jul 16, 2017Aspirant
Long story short, had a power failure. Modem did not come back in bridge mode. I logged on and set it to bridge mode and it locked up. Comcast could not get it to work after a number of resets with less than stellar support. They had me go to the local comcast site to exchange modems. Had to speak to first and second level support and finally they were able to shutdown wireless and put into bridge mode. If you have the same issue I did, look to make sure the Netgear router sees the actual providers IP address and not a private one.
gotcha. I suspected a lost of power last night too. I do not remember putting my modem into bridge mode when I first setup my AC1900 nighthawk router. The modem is from time warner. Do I turn on bridge mode through the router settings or getting into the modem settings?
Well, if you are using your AC1900 to hand out IP address (DHCP) and perform your port forwarding stuff, then your ISP modem should be in bridge mode. Basically what you are doing is giving the brains to your Netgear router and just pass the internet through your ISP modem. So, I would call Time Warner and confirm that your ISP modem should be in bridge modem, and that will be based on which device is performing the above functions.
