matscol2
Mar 17, 2022Guide
AC1750 R6400 web interface can't connect
It's been about 6 months since a reboot of the router and my R6400/AC1750 has dropped some but not all devices off the wired network it controls. It's in a remote location and I will have to travel t...
matscol2
Mar 17, 2022Guide
Thx for taking the time to respond. I'm accessing with IP addy and firefox eventually times out and says the site is unreachable. it's as though the built-in web server crashed.
Mar 18, 2022Guru - Experienced User
did you try other browsers?
- matscol2Mar 18, 2022Guide
yes, same result with IE and chrome
everything behind that router has dropped now except the one server i can get to (and that's the one thing on a fixed IP) so i guess router DHCP is down as well as the web server
sending someone to the site to reboot (and possibly change routers) but would still love to know if there's a way to fix this remotely when it happens.
- plemansMar 18, 2022Guru - Experienced User
If you can remote into a computer, you can reboot it through its menu. But when it goes down to where you can't access the router, then not. Then your only option might be a way to trigger a smart switch plugged into the router that cycles off and back on. It'd probably need that same static configuration.
switch is a good idea, i might try that
just so frustrating when i can ping it but not get to the web-based UI.
