matscol2
Mar 17, 2022Guide
AC1750 R6400 web interface can't connect
It's been about 6 months since a reboot of the router and my R6400/AC1750 has dropped some but not all devices off the wired network it controls. It's in a remote location and I will have to travel t...
matscol2
Mar 18, 2022Guide
switch is a good idea, i might try that
just so frustrating when i can ping it but not get to the web-based UI.
matscol2
Mar 20, 2022Guide
Just an update for anyone reading later looking for a solution, I sent someone out to reboot.
That plus a restart of some of the dropped devices to pick up new IPs was all it needed.
Not particularly helpful, I know, and doesn't lead me to know why it happens sometimes.
- michaelkenwardMar 20, 2022Guru - Experienced User
That is far from being not helpful. You may not have got to the bottom of what happened, but your "solution" could save someone else plenty of grief.
Thanks for the feedback.
