noctowl
Jul 04, 2023Tutor
AC1750 R6400v2 stuck on 802.11a\g?
For some reason, my devices (like windows laptops) are unable to use anything other than 802.11a on 5GHz and 802.11g on 2.4GHz. I noticed this because I was only able to download at 30mbps on 5GHz, and I've seen much faster speeds before. I am running the latest firmware at the time of writing (V1.0.4.128_10.0.104).
- 2.4GHz channel selection is set to auto, Mode is set to "upto 450 mbps"
- 5GHz channel selection is set to 153, Mode is set to "upto 1300 mbps"
- I have checked for signal crowding using the Ping Tools app on my phone, and congestion seems fine
- Airtime Fairness was on, but toggling made no difference.
- Beamforming is on
- WMM QoS is disabled
I'm at a loss. Is this a firmware issue? If it is, how can I file a bug report with netgear?
...and I fixed my problem... turns out it was WMM, I had disabled it to troubleshoot something else, but turns out that was what prevented things using faster network modes. Now I have 802.11ac lmao.
Turned airtime fairness back on after that, and it has not made any negative difference.
1 Reply
- noctowlTutor
