Thanatoastyyy
Mar 16, 2022Aspirant
AC1750 /R6400v2 throttling itself
I have a 1gb connection but barely seeing speeds of 100mbps. Ive called my isp and they said thats it is nothing on their side and that I should factory reset my router. After doing that it ran at 1g...
Mar 16, 2022Guru - Experienced User
1. what modem/gateway is the router connected to?
2. are those speeds wired speed? Wireless speeds?
3. what device are you checking speeds on?
4. have you checked your port statistics page?
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
Thanatoastyyy
So im not sure what modem/gateway it is, my router is plugged into a fiber optic line via a little box. Those speeds are wired and have been tested on my pc which is connected via Ethernet cord. Ive check on speedtest.net fast.com etc and got 1gb speeds after a full factory reset of my router. But it reverted back to 100mbps speeds. So while fiddling around in my routerlogin page i restarted my router sooooo.
