Thanatoastyyy
Mar 16, 2022Aspirant
AC1750 /R6400v2 throttling itself
I have a 1gb connection but barely seeing speeds of 100mbps. Ive called my isp and they said thats it is nothing on their side and that I should factory reset my router. After doing that it ran at 1g...
Mar 16, 2022Guru - Experienced User
1. what modem/gateway is the router connected to?
2. are those speeds wired speed? Wireless speeds?
3. what device are you checking speeds on?
4. have you checked your port statistics page?
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
Thanatoastyyy
Seems like my upload didnt work for my port stats, hopefully this one works stats
- schumakuMar 16, 2022Guru - Experienced User
For whatever reason, the one and only active LAN connection negotiates to 100 Mb/s only.
Typical cause is for wrong link rate negotiation is the cabling, or in the physical ports. Start with using a different cable.
What device (computer, switch, ...) is connected to the LAN2 port?
- ThanatoastyyyMar 17, 2022Aspirant
The only device that is running ethernet is my pc which is connected into port 2
- schumakuMar 17, 2022Guru - Experienced User
Great, so head to the troubleshooting.
