Thanatoastyyy
Mar 16, 2022Aspirant
AC1750 /R6400v2 throttling itself
I have a 1gb connection but barely seeing speeds of 100mbps. Ive called my isp and they said thats it is nothing on their side and that I should factory reset my router. After doing that it ran at 1g...
Thanatoastyyy
Seems like my upload didnt work for my port stats, hopefully this one works stats
schumaku
Mar 16, 2022Guru - Experienced User
For whatever reason, the one and only active LAN connection negotiates to 100 Mb/s only.
Typical cause is for wrong link rate negotiation is the cabling, or in the physical ports. Start with using a different cable.
What device (computer, switch, ...) is connected to the LAN2 port?
- ThanatoastyyyMar 17, 2022Aspirant
The only device that is running ethernet is my pc which is connected into port 2
- schumakuMar 17, 2022Guru - Experienced User
Great, so head to the troubleshooting.
It was happening with my new cable and my old. I originally thought that a 5-6 year old cable that was 100ft long could degrade the signal so i bought this. https://www.amazon.com/dp/B00GBBSTEG?psc=1&ref=ppx_yo2_dt_b_product_details
I did the factory restart on my router with just my new cable but after a month or so it reverted back to the 100mpbs speeds. Im almost 100% sure that its something to do with the router
- FURRYe38Mar 17, 2022Guru - Experienced User
What is the brand and model# of the ethernet adapter in this PC?
I think this is what youre looking for https://www.amazon.com/dp/B00GBBSTEG?psc=1&ref=ppx_yo2_dt_b_product_details
I was originally using a 100ft cord that was 5-6 years old and thought that might cause the speeds to degrade, so I changed to this one about 2 months ago. If thats not what youre asking the ethernet port on my pc is from my mobo which is a msi b450 tomahawk max. Sorry im not great when it comes to networking terms
