jdcoburn
Jan 03, 2022Aspirant
AC1750 router doesn't seem to support remote desktop.
hi -i previously had at least 6 windows 10 computers using remote desktop among each of them. when i upgraded to the AC1750, after some fiddling i got all my network restored except remote desktop. n...
jdcoburn
Jan 05, 2022Aspirant
In no particular order - Microsoft uses the term "Remote Desktop" both in their Windows 10 literature and in reference to the application foiund in "Windows Accessories > Remote Desktop Connection". if Netgear is not familiar with the term, i would suggest they read up on what > 75% of their residential users are using (ie Windows 10). "Fiddling around" is a polite way of saying that this was not a drop in replacement. My previous network with 6 PC's configured with static IPs set up between 10 - 100, with the DHCP reserved block 101 to 140. The starter app set up through the phone made some assumptions about where the DHCP address block was and it did not match my original scheme. it took some research to figure out how to change it - hence "fiddling around". i can now go to the router at 192.168.1.1 and review my configuration. it shows 29 devices at locations i expect. it also shows the device name for all the windows 10 devices next to the IP address. most are now assigned by DHCP but the router clearly sees the name of the device for each device regardless of whether it's an assigned static ip or a allocated DHCP.. Now when i try remote desktop, it will connect to 1 device provided i give it the IP address not the name (unlike previously when each device i wanted to connect to was accessible through either the IP address or its name.) no other device connects using remote desktop, regardless of whether i use the device name or the IP address. i would be tempted to say that it's related to the redirect of the DHCP reserved addresses but the one that works is at 192.168.1.134..All devices function normally except for the remote desktop connection. all devices have been rebooted several times and their configuration checked for remote desktop access.
michaelkenward
Jan 06, 2022Guru - Experienced User
Sorry. I can't read that. I find the return key very helpful
I am sure that Netgear is familiar with Windows "Remote Desktop" but it is one of those generic terms that could mean many things.
Had you said "Windows Remote Desktop" – the capital letters are also clue – the message might have been clearer.
We still have no idea what router you are fiddling around with. I can't find any Netgear router that has AC1800 wifi technology. AC1600, AC1900 and various ACXXXX yes, but no AC1800.
Try reading the label on the thing:
- jdcoburnJan 06, 2022Aspirant
Since you are obviously not a Netgear employee and have provided no useful information - please do not reply to any future posting from me.
- michaelkenwardJan 06, 2022Guru - Experienced User
You should know that this community is essentially a user-to-user venue with some input from a small band of Netgear techies.
Most of the answers come from fellow users who have no connection with Netgear. They just have a lot of collective experience and are familiar with the sort of problems that turn up here.
If you want "official" support then you should go through the right channels.
Contact Us | Support | NETGEAR
