Tallguy0406
Mar 09, 2022Aspirant
AC1750 Smart Wifi Router - Router speeds are slower than modem
AC1750 Smart Wifi Router Wifi5 Model R6350. Firmware version: V1.1.0.84_1.0.1 I've been monitoring my wifi speeds for the last week on 5G network. ISP is providing up to 200Mbps. Howeve...
Tallguy0406
Mar 10, 2022Aspirant
Do you have any suggestions as to which site to use when testing off of a PC?
Mar 10, 2022Guru - Experienced User
speedtest . net (try different servers on there, not just one)
fast.com
dslreports
all of them have speedtests. and when you get above a certain speed even they struggle to saturate speeds.
- Tallguy0406Mar 11, 2022Aspirant
Tested several sites with the WIRED connection to my PC. All was well and meeting the right speeds.
The WIRELESS connection is what is not meeting the optimal speeds I'm paying for.The router is located in the middle of my home and no matter where I am in it, the speeds are between 80 and 100 mbps. I am paying for 200 Mpbs for now since I have a small household of just 2 people.
What else can I do?- plemansMar 11, 2022Guru - Experienced User
did you try changing the wifi channel you're testing on?
Or try a factory reset/reinstall?
