Joelson
Oct 11, 2019Aspirant
AC1750 Smart WiFi Router 802.11ac Dual Band Gigabit
R6400-v2 - Firmware Version V1.0.4.82_10.0.57 How can I fix a IP Address to a device (printer) conected to my router?
- Oct 11, 2019
You could set a static ip address or IP reservation. Ip reservation is probably the easiest if you don't know how to do it.
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
Oct 11, 2019Guru - Experienced User
michaelkenward
Oct 12, 2019Guru - Experienced User
and/or, for a belt and braces approach, use the printer's control software to set an IP address.
- antinodeOct 12, 2019Guru
> software to set an IP address.For an explanation of why using both methods ("and") would be unwise,
see:
https://community.netgear.com/t5/x/x/m-p/1807693#M140271
It's not complicated, but not everyone seems able to understand it.
