sgtjjj
Feb 25, 2018Aspirant
AC1750 will not connect to internet after reset
My wifi bands quit broadcasting on my AC1750 and when I checked Genie I saw that the "Enable wifi" buttons were greyed out. The recommended solution for that was to do the paperclip reset button pro...
- Feb 26, 2018
Thank You, that did it. Patience was never my greatest virtue!
michaelkenward
Feb 26, 2018Guru - Experienced User
When you mess around with the settings of bit of the network you need to restart the whole network in the right way.
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
By the way AC1750 is not a Netgear model number. It is a label that Netgear, and others, attach to their hardware to describe their wifi speeds. Netgear makes a bunch of AC1750 devices.
On the wifi thing, what did the wifi LED look like? Any chance that someone press the wifi on/off button?
- sgtjjjFeb 26, 2018Aspirant
- michaelkenwardFeb 26, 2018Guru - Experienced User
That's good news. Glad it worked out, and thanks for reporting back. The "Solved" flag could help someone else in future.
I bet you wasted more time by just diving in!
