MattsSalty
Apr 26, 2023Follower
ac1750 wont turn green
I have a ac1750 that's a little older and no matter how close I have it to my wifi router or reset it, it will not turn green it only stays amber and will not change can someone please help me
michaelkenward
Apr 27, 2023Guru - Experienced User
Which LED is this?
If you mean the LEDs on the Ethernet port, that is usually a speed indicator for the connected device. Amber = 100 Mbps, Green = 1000 Mbps.
