nsham's avatar
nsham
AC1750/R6400 v2 Slow internet speed
I have Uverse Gig speed and hardwired from that router, I get on average 900mb download and around 750 upload but through the Netgear router using the same cable and connection, I barely get over 250.  I get faster speed on my phone and other devices NOT connected to the Netgear Device.
WMM and QoS are not enabled and the firmware is updated to V1.0.4.106_10.0.80.  No parental controls are enabled as well.
I have seen on a few other posts that there was a bad firmware update a while ago and some users were able to solve the issue by downgrading....is that still the only fix?
  • plemans's avatar
    what firmware do you have on it?
    what gateway do you have?
    Did you factory reset and do a clean install?
    make sure to leave disabled: qos, parental controls, access controls, and traffic monitoring.
    also, att is notorious for using gateway/router devices which can cause a double nat.
    https://kb.netgear.com/30186/What-is-Double-NAT
    FYI, WMM should be enabled.
    • nsham's avatar
      nsham
      Thanks for the response.....firmware is listed in the first post - V1.0.4.106_10.0.80
      I did a factory reset before posting the question
      I had a Linksys router and had no issuses with it and have been with ATT for years.
      I will try the factory reset again
      • plemans's avatar
        What att gateway is it?
        Some routers have issues with double nat.
