The_Roman99
Nov 21, 2020Tutor
AC1900 C700v2 Connection Drops
I have had the Nighthawk AC1900 C7000v2 for awhile now and what seems like everyday now, I will lose connection and have to sit for a few minutes untill it reconnects. This has been happeneing for as...
- Nov 23, 2020
If you have any splitters, amplifiers, or attenuators in the coax line remove them.
Check the line for kinks, bends, poor/old/cheap/bad connectors. Also, check for loose connectors.
Move the C7000 to right where the coax enters the home and connect there.
Reason I say this is your log is showing line issues, power lissues. The dynamic range window violations are when power goes above/below spec. And you have many t3/4 errors. This together indicates a line issue/cmts issue.
The_Roman99
Nov 23, 2020Tutor
Here it is. Sorry I really don't know much about this sort of thing.
Nov 23, 2020Guru - Experienced User
- The_Roman99Nov 23, 2020Tutor
So if my cable coming out of my wall is all good, what I am hearing is my ISP needs to work on the lines in my area? I will look into my cable after work today thank you!
- plemansNov 23, 2020Guru - Experienced User
Yes have them check the lines. Somethings causing your power levels to flucatuate outside of the power window and its happening a lot.
