levernhoover
Aug 08, 2023Follower
ac1900 nighthawk set up software problems
the ac1900 nighthawk set up software sees the router but does not connect to set up the booster.
michaelkenward
Aug 08, 2023Guru - Experienced User
What ac1900 nighthawk is this?
ac1900 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
What is this booster?
