LeslieN
Feb 13, 2020Aspirant
AC750 Dual Band WiFi Router
We need a router that will work best with our 300Mbps internet for an approximately 1400 sq. ft. home. Would the R6020 AC750 Dual Band WiFi Router be a good fit for us? There's only two of us in th...
- Feb 13, 2020
> [...] 300Mbps internet [...]
> [...] Would the R6020 AC750 Dual Band WiFi Router be a good fit for
> us? [...]I'd say no. Visit http://netgear.com/support , put in that model
number, and look for Documentation. Get the User Manual or the Product
Data Sheet. Look for the Ethernet port speeds. I see specifications
like the following (from the Product Data Sheet):Five (5) 10/100Mbps (1 WAN and 4 LAN) Fast Ethernet ports with
auto-sensing technologyWhere "Fast Ethernet" means faster than the typical speeds in 1985.
If your Internet connection is faster than 100Mb/s, then you should
probably look for a router with "gigibit" (1000Mb/s = 1Gb/s) Ethernet
ports. I wouldn't limit my search to Netgear, either.> [...] we typically only have one TV streaming at a time.
I'd expect 10Mb/s to satisfy that requirement, but if I were paying
for a 300Mb/s connection, then I'd want at least some probablity of
getting more than a third of that.
antinode
Feb 13, 2020Guru
> us? [...]
- LeslieNFeb 13, 2020AspirantThank you! I appreciate the info!
