Retired_Member
Oct 20, 2020AC750 extender model EX 3700 no Internet to access set up
I have had extender for a year so no support. Yesterday I had my router replaced, I was mid set up for the extender after a factory reset when I was booted for inactivity mid set up. Since then I can...
Oct 20, 2020Guru - Experienced User
Try factory resetting the extender 1 more time.
Push and hold reset for 7-15 seconds while powered on.
Then to set it up, hardwire into it from a pc/laptop. Disable the pc/laptops wifi during setup so it doesn't default back to that connection.
Then set it up using the installation assistant and not wps.
What router is it connecting to?
Retired_Member
Oct 20, 2020Thx I will absolutly try that, however I can't work out what cable I would need to connect the extender to my laptop? Can you advise?
The extender was connecting to my Hub 3 Virgin router, as I can't set it up it's currently not connected to anything.
- plemansOct 20, 2020Guru - Experienced User
Retired_Member wrote:Thx I will absolutly try that, however I can't work out what cable I would need to connect the extender to my laptop? Can you advise? ----An ethernet cable. The EX3700 has an ethernet port you can hardwired a pc/laptop to. tends to make install faster/easier.
- Retired_MemberOct 20, 2020
The extender does have an ethernet port but my laptop doesnt? Can you advise what kind of cable or adapter I would need to connect it to my laptop (post link or picture if poss, my laptop is brand new)
- plemansOct 21, 2020Guru - Experienced User
You don't have to connect to it wired for setup. It just tends to make things easier/faster. It should be able to be done wireless.
but you can get a usb---ethernet adapter. You can find a bunch of them.
https://www.amazon.com/s?k=usb+3.0+ethernet+adapter&i=electronics&ref=nb_sb_noss_2
Just make sure your new laptop has a usb 3.0 port (2.0 would work as well). Or if it has a usb-C adapter, then you'd want that type of usb adapter.
