AcoO44
Dec 16, 2020Aspirant
AC750 model EX3700
I've had my AC750 range extender model EX3700 for three years without problems, I use it to connect my smart tv. 2 days ago I started to get problems and noticed that the Client link LED was out, I ...
Dec 17, 2020Guru - Experienced User
Client link light is for devices connected to it.
do you have a device connected to it?
AcoO44
Dec 17, 2020Aspirant
Yes, smart LG tv, using Ethernet.
- plemansDec 17, 2020Guru - Experienced User
any wifi devices?
Do other devices have issues connected to it?
What firmware is on it?
what are all the leds doing (color, blinking)?
what router is it connected to?
Did you set it up using wps or the installation assistant?
Has a simple factory reset and reinstall been tried? (not reboot but a full reset)
- AcoO44Dec 18, 2020Aspirant
Hi, thanks for your response,still getting problems.
Netgear used only to support LG tv
Router is Fritz!
Router and Power LEDs all green, not blinking
Router Arrow usually green, occasionally yellow
set up by wps
sorry, I'm not an IT wizard so can't really answer your other questions
no issues with other devices (iPad, phone, PC)
