melaniep
Mar 06, 2021Follower
AC750 wifi range extender - forgot password during set up and need to change it. How?
Hi,
My partner got a AC750 wifi range extender.
He started setting it up and made a password for it and forgot it. Now we cannot connect and finish the set up process. Can we change ? as its still not connecting to the original router
1 Reply
You could always factory reset it to get back to the defaults so you can follow the stock install guide.
simply push and hold reset for 7-15 seconds while its powered on.
