Natims
Jul 27, 2018Aspirant
AC750 wIfI ROUTER R6020 password issue
Router is currently hooked up and working fine for my Roku TV system. I'm trying to connect to the internet with a laptop running win7. The computer finds the router with sidi netgear81. But then it ...
- Jul 28, 2018
I found under where it wanted the 8 digit pin there was a link that said "or enter network key code" . I clicked on that and entered that fluffyship 347 and it worked. Problem solved. Thanks anyway.
Smitty70
Jul 27, 2018Tutor
Try typing the password in Notepad, then copy/paste it from Notepad to the password field.
If you need, you can update the password on the router, but you'll then have to reconnect all your other devices.
