Natims
Jul 27, 2018Aspirant
AC750 wIfI ROUTER R6020 password issue
Router is currently hooked up and working fine for my Roku TV system. I'm trying to connect to the internet with a laptop running win7. The computer finds the router with sidi netgear81. But then it ...
- Jul 28, 2018
I found under where it wanted the 8 digit pin there was a link that said "or enter network key code" . I clicked on that and entered that fluffyship 347 and it worked. Problem solved. Thanks anyway.
AliceKelly
Aug 10, 2018Aspirant
I'm an old fart with a computer science degree. No big deal really. The version of windows was made before the need for ten digit passwords and therefore won't take the pass. Upgrade to windows 8/ 10 or download a version of Linux that has your laptops firmware pre-installed. The router is fine. The laptop is fine. The software / operating system is to old.
