JudeGlad
Jun 05, 2021Aspirant
AC791L Jetpack portforwarding error request timed out 25565 port
I have portforwarded 25565 and I have started my Minecraft server and it is listening on port 25565 [21:42:39 INFO]: Starting Minecraft server on *:25565 I have turned off my firewall i can't turn ...
antinode
Jun 05, 2021Guru
> I have portforwarded 25565 [...]
How, exactly?
> [...] and I have started my Minecraft server [...]
On what?
> [...] I have turned off my firewall [...]
_You_, personally, have a firewall? Or do you mean some firewall or
other on some gizmo or other, or what?
> I ran canyouseeme [...]
Which is testing which IP address? And "yours" is?
For the usual problems with port forwarding, see:
https://community.netgear.com/t5/x/x/m-p/1859106
Hint: Usual problem number 1 in that list is number 1 for a reason.
> Model: AirCard 791L|Verizon Jetpack 4G LTE Mobile Hotspot (AC791L)
- JudeGladJun 05, 2021Aspirant
i went to 192.168.1.1 went to advanced and port forwarding and then entered 25565 as the port and entered my local ip hit save then restarted the aircard
I started my Minecraft server on a pc?
i turned off windows defender firewall
why do I have to give you my public IP address that is private
- antinodeJun 06, 2021Guru
> [...] entered my local ip [...]
"my"? _You_, personally, have a local IP address? Or did you mean
the IP address of some computer or other on your LAN? Or what?> https://community.netgear.com/t5/x/x/m-p/1859106
Look for "How did you ensure [...]?".
Are you asking me or telling me? Its IP address?
You don't need to give me anything. It might be helpful if you
compared "the IP address of the WAN/Internet interface of your router"
with "what you're using as your public IP address from the outside
world".
> https://community.netgear.com/t5/x/x/m-p/1859106Did you look at it?
- JudeGladJun 06, 2021Aspirant
the IP address of some computer or other on your LAN? Or what?i entered the IP of my computer that is running the Minecraft server if its helpful the IP is 192.168.1.144 (this is not the ip of the Minecraft server this is my computers local ip address)
there was nothing saying that I had to specify what the port forward was for or anything, it just let me port forward
i didn't know what you ment when you said "on what" so I just said my pc
if you want my local ip its 192.168.1.144
