Camielvand
Jul 10, 2022Follower
AC797-100EUS in the united states
Hi there Question: will the AC797-100EUS also work in the USA and Canada. According to the specs i presume it does but i’m not that Technical. Can someone confirm? Thx
michaelkenward
Jul 11, 2022Guru - Experienced User
Camielvand wrote:
Hi there
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
I will ask the Netgear moderator to move your message.
