Palmtreehugger
Nov 16, 2016Aspirant
Access denied to ebay
I have a WNDR 3700 and have had no issues until right now. All of a sudden it's denying me access to ebay. I called ebay and they said not on there end. I called my ISP and they said the same thing. ...
- AnonymousNov 16, 2016
go to setup....internet setup.... change MAC address by selecting use default or use pc mac which ever one uses a different MAC.
click apply then reboot MODEM this should change your IP, if it was blocked it should now work with new IP.
Before changing Note your IP to be sure it did change.
Anonymous
Nov 16, 2016go to setup....internet setup.... change MAC address by selecting use default or use pc mac which ever one uses a different MAC.
- PalmtreehuggerNov 16, 2016Aspirant
Thanks for the help. Whe you say setup do you mean setup at Netgear or my computer? I don't see a setup in the netgear smart wizard page. I need the netgear for dummies book. Exactly where do I go to change the mac? What do I change it to?
I found it. Working on it now.
Thank you Searay. Worked as promissed.
Not that it matters but, the question should be why did ebay block your IP assuming it did change.
Glad it worked,
You're Welcome!
I called eBay first thing. They said "not on our end" I have 17 years 1284 100% feedback. They love me. They said call Cox. Cox said "not us" check your router. Router said "I'm your Huckleberry" better see Searay to fix me.
