Palmtreehugger
Nov 16, 2016Aspirant
Access denied to ebay
I have a WNDR 3700 and have had no issues until right now. All of a sudden it's denying me access to ebay. I called ebay and they said not on there end. I called my ISP and they said the same thing. ...
- Retired_MemberNov 16, 2016
go to setup....internet setup.... change MAC address by selecting use default or use pc mac which ever one uses a different MAC.
click apply then reboot MODEM this should change your IP, if it was blocked it should now work with new IP.
Before changing Note your IP to be sure it did change.
Retired_Member
Nov 16, 2016go to setup....internet setup.... change MAC address by selecting use default or use pc mac which ever one uses a different MAC.
Palmtreehugger
Thank you Searay. Worked as promissed.
Not that it matters but, the question should be why did ebay block your IP assuming it did change.
Glad it worked,
You're Welcome!
- PalmtreehuggerNov 16, 2016Aspirant
I called eBay first thing. They said "not on our end" I have 17 years 1284 100% feedback. They love me. They said call Cox. Cox said "not us" check your router. Router said "I'm your Huckleberry" better see Searay to fix me.
Last question did the IP change?
